F935 lift cylinder leaking. Rebuild kit?
   / F935 lift cylinder leaking. Rebuild kit? #1
VA Rebel
Bronze Member
Ole Virginny
JD4100, JD2555, JD2155, JD5225, JD7720 Combine
Just seeing if anyone has found the seals to rebuild the F series lift cylinders. New ones are like 250 and deere doesn't show a kit in their parts.
   / F935 lift cylinder leaking. Rebuild kit? #2
Isn't that cylinder welded together? either way a good hydraulic repair place should be able to fix it, but you'll be real close to the price of a new one
   / F935 lift cylinder leaking. Rebuild kit? #3
Quite a few used ones on ebay. A pair for $110 plus $20 shipping.
Thanks guys. I was trying to avoid an old one because I figure those seals probably aren't far behind since they are around the same age.
Land Honor Skid Steer Winch (A50515)
Land Honor Skid...
John Deere 9450 Combine (A50514)
John Deere 9450...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
Kubota B2410 (A47384)
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
