F935 electric fuel pump part numbers
/ F935 electric fuel pump part numbers #1
ahayden
Alto, MI
Allis Chalmers WD45
The parts list shows two different part numbers for the electric fuel pump for the F935 mower. Based on serial number (11247) am876116 is the one we need but there's very little to be found via Google and it's $300. However, am876266 is all over the place and a whole lot cheaper. Can anyone tell me the difference between the two? I see where am876266 is listed with a black connector or a white connector. The white connector appears to be the same as the old pump on the mower. I am wondering if the pressure and flow rate is the same between the two pumps or if it's different. The old pump has JKC, 0212, and 2000 stamped on it but none of that info comes up in a search. I'm thinking that I can use the am876266 as long as I get the white connector, but I hate to assume and find out that there is a difference.
/ F935 electric fuel pump part numbers #2
Probably the best thing to do is ask the local JD parts rep to get the specs on each pump. They can get that info for techs and to explain the added expense between the two.
