F935 deck not engaging
   / F935 deck not engaging #1
ycarl400
F935
Hi, I have a 2000 f935, the mower deck just quit after 30 minutes of mowing. The deck now just turns on for about 5 seconds and shuts off. The mower has about 2200 hrs on it now. The switch ohms out ok. Any help would be appreciated.
   / F935 deck not engaging #2
If it just suddenly stopped, I would suspect a bad safety switch. If it runs briefly, it is likely going to be difficult to figure out. This is because whatever is the issue requires a bit of heat to show up. This is not likely to happen with ohm testing.
Try testing for voltage through the switches. I would isolate each switch from the others in the circuit and run 12 volts through each and test continually for 30 seconds to 1 minute.
   / F935 deck not engaging #3
Low voltage allowing clutch to drop out, or pto clutch itself is failing
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
