fdf250
I recently bought an extremely clean and low hours (388) John Deere f735 diesel. I haven't really used the machine at all since I bought it but spring is here so I went to do an oil change on it last night. The manual calls for 2.5 qts. of oil without the filter which I put in as well as a new fram oil filter. After the change I started it up to check for leaks and there were none. I shut the engine down to check the oil level and oil bubbles out of the dip stick. This happened 3 times and now the dipstick is reading at the lower most hash mark. Is there a breather or pcv valve that could be clogged. I so does someone have a location to look because I have not been able to locate it. Thanks. Anthony
