F510 Mower
/ F510 Mower #1
JimCamp
Booker, Tx
John Deere F510 mower
I have a 95 JD F510 front mower. It starts and runs fine, after 15 minutes the mower stops, but the engine still runs fine and I can drive the mower. After it cools down it will mow again for about 15 minutes and stop again. I have replaced the PTQ switch but it still does this.
/ F510 Mower #2
Check the current to the electric slip clutch. If there is juice there, then the slip clutch is going bad. If the light bulb is off, then its an electrical supply problem. I have a 525 (48" mower deck) so I'm guessing its the clutch (easy to change). $180 bucks, though.
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
Gen Eye Pipe Inspection System (A65579)
Gen Eye Pipe...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
2017 GEHL RS6-34 TELEHANDLER (A62613)
2017 GEHL RS6-34...
