F3680 solid front tires
/ F3680 solid front tires #1
Barnbuilder
Waxhaw, NC
Bobcat A300, Kubota F3680, JCB 212S sold
Just replaced one of the deck wheels tubes. Made it one mowing. All the tires that show up on a search have a 5/8" bore. Not sure if I can swap the oem wheels to the aftermarket to make it all work. Anyone have suggestions. They're not cheap.
/ F3680 solid front tires #2
5/8" is a pretty common axle size. Get the outside diameter of your wheels and thickness at the axle. You may be able to get wheels with solid tires for cheap at Harbor Freight. You could also try filling them with foam making them a semi solid wheel.
/ F3680 solid front tires #3
Are you front deck guys mowing mostly smooth ground ?
I wanted a F3990 4wd BAD for my steep hills & banks : but my farm ground is bad rough & I knew my 3 RFM behind tractors for 20yrs took a beating running on the ground.
I’m currently running Two ZD1511 72 SD with fluid filled rear tires mowing 15 acres.
/ F3680 solid front tires #4
Is F3680 using 3/4" gauge wheel axles?
I use Carlisle solid rubber gauge wheels in my F3060 and they work good.
The mower was fitted with Marathon brand solid rubber wheels when I bought it few years ago.
The gauge wheel axles are smooth 3/4" water hard drill rod which can be purchased 36" long and cut to proper length - both ends need 3/16" holes for cotter pins.
Replacement solid rubber tires & bearings were also pretty easy to find on the eBay.
/ F3680 solid front tires #5
I put TireJect in my F3990 wheels and haven't touched them since. I think I doubled the recommended amount - maybe 4oz per tire. Easy enough since it came in an 8oz container....
Cool. I bought another set of tires & wheels. I'll have to try the Tireject. Thanks!
/ F3680 solid front tires #8
I have been leary of my F3680 tires failing, but they haven’t failed. Pretty tough little buggers, but theyre only 1.5 years old.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
2009 FORD F-750 SUPER DUTY (A67714)
2009 FORD F-750...
2011 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2011 Dodge Ram...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
2013 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2013 Toyota Tacoma...
