F150 ecoboost drilled my intercooler
   / F150 ecoboost drilled my intercooler #11
Yes this has happened but I have only heard of one story with the thousands produced. More common is a misfire code that gets triggered. The one time mine took a sip, I just had a loss of power for about 5 seconds but no codes. Figured this was an easy insurance policy.
I am happy you found a solution to this issue. That being said, why should you have to drill a hole in the intercooler of a $40k truck? If Ford put this motor through all these supposed torture tests (btw I do not believe much of what the big 3 say) shouldn't this have been addressed before getting in the hands of consumers? Maybe it is my old school way of thinking, but anytime I encounter water and oil mixed, I become concerned. Granted, I do not know much about the EB engine. Most people seem to like them. But for reasons like this, issues with the 6.0 diesel(the 2 I owned were o.k.), spark plug blowouts, etc. is why I have not owned a Ford since 2006. And it's not just Ford. GM and the oil consumption issues, Dodge and the weak front ends and transmissions, I could go on. Maybe we become so brand loyal we wear blinders and think issues like this are acceptable. For the amount of money these trucks cost, it simply is not. Had it been my truck, it would be at the dealer being addressed with plenty of backup documentation. When looking at trucks, I usually do a lot of research, speak to neutral parties, such as local mechanics, and make a decision based on dependability, cost of ownership and practicality. The EB has too many moving parts and may become a maintenance issue down the road. I am happy you like yours and truly hope your issue is resolved.
   / F150 ecoboost drilled my intercooler #12
Thanks for sharing that. I have had one shudder in 45k miles. Might drill the hole just to be on the safe side. The next question is, how long to keep the EB? I usually trade at 100-120k miles but am a bit concerned about turbo related issues cropping up before that. The F150 forums have lots of discussion of the stumble but I haven't been able to get a clear idea how the engine holds up at 100k and above.
   / F150 ecoboost drilled my intercooler #13
This problem is not likely to show up when fully loaded and running it hard. It will only really show up with cool ambient temperatures and light load on the engine.
This problem is NOT unique to Ford, it has been found on many vehicles with intercoolers. Volvo had some issues on the 850 or S/V70 (IIRC) with ice building up in the throttlebody with humid air and subfreezing temps (water would build up in the IC, be evaporated by the hot air, then condense and freeze on the throttle plate causing ice to build up and make the throttle stick. Their solution? Drill a small (1/16" or 1/32") hole in the bottom of the end tank on the "out" side of the IC.
Search for "intercooler weep hole" for more such stories from Volvos, VWs and Caddys (and that's just the first half dozen results).
Aaron Z
   / F150 ecoboost drilled my intercooler #14
Aaron Z
Did not know it was widespread-thanks for sharing this info.
   / F150 ecoboost drilled my intercooler #15
In the right conditions (high humidity, low boost), the intercooler can cool the air down enough that it will condense water out of the air and leave you with a slug of water in the intercooler. If you suddenly call for more airflow (such as when you stomp on the gas to pass someone) it can suck the water out of the intercooler and into the engine. Being as water is not very compressible, you can hydrolock the motor and bend rods if it ingests enough of it at a time.
Aaron Z
Has this actually happened, or is it someone's theory?
We just ordered a Ford Transit 250 with the Ecoboost. The joke on the Transit forum is "Eco, or boost: pick one....."
   / F150 ecoboost drilled my intercooler #16
Holy smokes, it makes me glad that I did not get the eco-boost option with my new 2014 F1 50! I got the five leader, and it is a lovely engine so far (3 months new). Maybe when my lease is up two years from now, they have will have fixed these problems with the eco-boost engine!
   / F150 ecoboost drilled my intercooler #17
It is theoretically possible, generally speaking, its just enough to cause a misfire.
The EcoBoost in the Transit is detuned (compared to the one in the F150) and it probably has a different intercooler setup, so it will have different manners and probably different problems.
Aaron Z
If I were to take it to the dealer, their approved fix is to make the intercooler less efficient with a plate that restricts airflow. The real fix is to drill the hole which the dealer won't do probably because it would violate some EPA rule. I would rather have a hole and enjoy the benefits of an efficient intercooler.
I don't understand your concern with water and oil being mixed.
There are mods and improvements to just about anything you buy. Just glad this one was a free five minute fix.
   / F150 ecoboost drilled my intercooler #19
So is this hole left permanently open? Sounds like a worse fix than the one Ford does, IMHO. All that extra efficiency from the larger cooler is swishing out the little hole, in the form of lost boost. Not a huge amount but still a loss. You yourself mentioned a large amount of escaping air. It seems to me this is more of a plumbing design that intercooler efficiency issue.
As for Ford not forseeing this, there isn't a car company in the world that tests their cars for EVERY possible malfunction. It's just not possible or financially practical. Their R&D would make the truck even more expensive, and no doubt there will still be issues crop up that could not be seen.
As for the Ford 6.0 Diesels, that's why Ford makes their own diesel engines now, at least for the light duty trucks. The 6.7 seems to be pretty issue free, so far.
   / F150 ecoboost drilled my intercooler #20
Interesting. I can't seem to understand why this truck has an issue with moisture in the intercooler as I have never run into this on the other trucks and equipment I have run with an intercooler. Can't see how being gasoline would make a difference as this is just air that has been run through a turbo when it's inside the intercooler.
2008 FORD F-650 (A50854)
2008 FORD F-650...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2015 MACK GU713(INOPERABLE) (A50854)
2015 MACK...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
