F.Y.I OIL FILTER UPDATE
   / F.Y.I OIL FILTER UPDATE #1
CHUCKWAGON
TENNESSEE
FARM PRO 30 HP 4X4
I HAVE A 2430 4 X 4 FARM PRO, I'M SURE THIS PROBLEM INVOLVES OTHERS ALSO. ( it can't be just me )
OK, ANYONE HAVING A PROBLEM TRYING TO FIND A REPLACEMENT OIL FILTER FOR THERE TRACTOR, THIS INFO MIGHT HELP YOU. I FINALLY GOT MY PROBLEM ALL FIXED.. /forums/images/graemlins/wink.gif
OK AFTER MANY WEEKS OF RESEARCH, TRIAL & ERRA AND
EXTRA GRAY HAIR'S, THIS IS WHAT I FOUND. THE PIPE THREAD AT THE OIL FILTER HOUSING NEEDS TO BE EXTENDED, IT WAS TO SHORT FOR ANY OTHER FILTER TO SCREW INTO, BECAUSE THE ORIGINAL FILTER IS BEVELED. I REMOVED THE FILTER HOUSING OFF THE MACHINE AND TOOK THE PIPE THREAD OFF, ( it needed a little heat ) I BROUGHT IT TO NAPA AND IT TURNS OUT THE THREAD IS 3/4 X 16 AND A NAPA 1515 A BASIC FORD OIL FILTER FIT PERFECT. yaa-whooo /forums/images/graemlins/cool.gif (THE 20 X 1.5 WAS LOSE & SLOPPY)
I CLEANED THE PIPE THREAD AND PUT A FEW DROPS OF BLUE LOCK-TIGHT ON IT AND SCREWED IT BACK IN THE HOUSING SO APPROXIMATELY 1" WAS EXPOSED, LET IT SIT FOR 24 HRS AND REASSEMBLED IT BACK ON THE TRACTOR.
I PRIMED THE FILTER WITH 15 - 40 (a secret a member told me) SCREWED IT IN PLACE, FILLED THE OIL PAN AND NOW I'M BACK IN BUSINESS AGAIN.
SO FROM HERE ON, IT'S A PIECE OF CAKE TO CHANGE THE OIL & FILTER ON MY TRACTOR. NO MORE GOING CRAZY.. /forums/images/graemlins/laugh.gif
I HOPE THIS INFO HELPS YOU, IT'LL SAVE YOU A LOT OF TROUBLE, AND HEADACHES. CHUCK..
   / F.Y.I OIL FILTER UPDATE #2
Great news !!! I have a 284 built 12-2004 , the oil filters listed on web sites do not fit my newer Jinma, Sounds like you have answer !
Thank you, saved me a lot of work. /forums/images/graemlins/laugh.gif
Unused Delta Crash...
Kuhn GA6002 (A50123)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2017 FREIGHTLINER CASCADIA SLEEPER (A53426)
2017 FREIGHTLINER...
