F Series Glow Plugs
   / F Series Glow Plugs #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Yes, some of the later model tractors have glow plugs. My impression is they burn out frequently. I'm in the process of replacing all three. Got them from Hoye tractor.
Also, the voltage regulator seems to burn out easily. Mine went and when I took the old one out the screws attaching it to the tractor were already well used. BTW watch the screws they are of some very soft metal.
   / F Series Glow Plugs #2
The voltage regulators Yanmar used seem to be a frequent replacement part. This is true of the older YMxx00 tractors as well as the YMxx01, and YMxx02's. It would seem that it is true for the F series as well.
   / F Series Glow Plugs #3
Perhaps your glow plug problems and current limiter problems are related? Did it happen after jump starting the tractor? Someone told me that the current limiters are not rated for more than battery voltage on the battery side, so you should not jump start the tractor from a running vehicle. I have not taken the time to review the schematics to verify, and I have my doubts. Did all of your glow plugs burn out at once? All of my tractors have had all good or all bad glow plugs. It seems like at least one of them would still be good some of the time. Perhaps it is voltage related or from over heating the engine?
   / F Series Glow Plugs #4
I haven't replaced many Yanmar glow plugs but lots of Iseki plugs. Rainbow Distributors have been a good resource for any hard to find ones.
Nick
I think mine came bad from Japan. It never did start well in the Winter. I'm pretty sure they are all bad. Regulator has been good until last summer. They should be here by Wed. so I can get this thing back together. Spring is here.
   / F Series Glow Plugs #6
Ah ha! This is the reason. Glad I search for this here. It may be an old thread, but here is the answer!
Yes, I had to jump start the tractor. Noticed when turning the key to the left, the bulb for the glow plug would NOT light up there after. Took the lamps out and 2 of the 3 were blown. Thought, ok, just the bulbs then. Well, after replacing the bulbs, the glow plugs still didn't kick in.
I did try to jump start with one of those portable packs, but it was just a wee-bit shy of having the Yanmar YM2610 turn over. Thus, I used the vehicle. Bummer folks, wish I had know this from the beginning. Pulling the battery and bench charging would have been best.
For the YM2500/YM2610, the battery location basically can take and group size battery with the posts on top. I found the RV/Marine gel cell group-31 to work really well for now.
Looking at the fuse box, each fuse looks to be in good shape and passes a volt meter continuity test.
Got to now trace the glow plug issue further. It's winter now. The next few days are in the 50s before it drops once again.
   / F Series Glow Plugs #7
The 2610 does not have glow plugs, it has thermostart heater in the intake.
   / F Series Glow Plugs #8
Oh, now it's even harder to figure this out. haha Back to square 1 to figure what is a thermostart heater. :p
I only assumed it had glow plugs like the others.
Why does Hoye show this for the YM2610 ???
Home/ YM2610_2610D» ELECTRIC» GLOW PLUG (THERMO-START PLUG)
GLOW PLUG (THERMO-START PLUG): Yanmar Tractor Parts
Does it have BOTH ??? I'm looking for any intake heater too. :)
Now, I'll have to look thru all of those scanned pages. :duck:
So, there isn't much to go by on the heater or glow plug in this ... Anyone got an idea in this image? Maybe R1 ???
   / F Series Glow Plugs #9
   / F Series Glow Plugs #10
You only have a thermostart plug. Tried to circle it with paint but wasn't smart enough to do it. Just follow the little hose down from the bottom of the little container. The thermostart screws into the top of the intake manifold. Your 2610 may not be exactly like the picture of my old 2002D but will be similar.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
2022 John Deere 325G Skid Steer (A50657)
2022 John Deere...
