F-150 dying question...
/ F-150 dying question... #11
I own a F150 although much newer. I’d guess the truck is a 1980’s or early 90’s truck. I know from being on the F150 forums it’s common the two tank setup has problems and it seems a lot of people give up on one of the tanks. I don’t know the cause or the solution though.
/ F-150 dying question... #12
Having worked in a Ford dealer from 84 to 98, the problem rings a bell. Unfortunately, my memory banks have been cleared of those not so fond memories. Plastic cannister with filter and switch over valve may be at fault.
/ F-150 dying question... #13
Some things I'd ask are:
- How exactly does it die? Does it start sputtering then die or does it just turn off?
- Can you restart it immediately? If not, how long until it will start again?
- If it doesn't restart immediately, does it sound like it wants to start but can't, or does the engine just spin?
- If it doesn't restart immediately, is there something you can do to make it start, like maybe with starting fluid, etc?
If you've seen it die after a mile as well as after 100 I'd bet it's not a fuel problem. We had a couple older vehicles that did this exact thing and it was the ignition module. You might get 1 mile or you might get 100, and if you waited a while it would just magically restart as if nothing was wrong. Hot, cold, didn't matter - it was totally random.
/ F-150 dying question... #14
If it's old enough to have a distributor I would throw a cap and rotor at it. Have seen the distributor rotors open when they are hot.
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
John Deere 5055E (A53317)
John Deere 5055E...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
