EZtrak Z445
/ EZtrak Z445 #21
Yes, I work for Sloan Implement and I work on lawn mowers. I would check out to make sure that your front of the deck is 1/8" lower than the rear, that your wheels are 1/4" off the ground, and that your blades are level side to side. There is no reason why this should be happening otherwise. If you still cannot figure out the problem, I would suggest taking it to your local John Deere dealership and they will be able to solve your problem. I hope that this helps.
/ EZtrak Z445 #22
I just got a Z445 with a 54 in. deck and used it once so far. I'm very pleased. I was a little apprehensive about learning to use a ZTR mower but the learning curve wasn't bad. Still need some fine tuning. However, it cut my mowing time from 3 hours to about 1 hour 45 minutes. I have 2 other JD's, a LX 288 lawn tractor and a 870 compact tractor. All good quality products. I recommend the Z445.
/ EZtrak Z445 #23
I've been looking at the ez445, it seems like a nice compromise between a residential and a full blown commercial for a good price. JD has just increased the warranty to 4 years as well. I was thinking a used commercial mower but with the 4 year warranty I think I found my ZTR. I have just south of 4 acres, is the 54 inch with high capacity deck the way or should I go with the ez465 with the 61 inch standard deck?
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
PORTA POTTY (A67714)
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
IRanch High-End Tricycle (A64119)
IRanch High-End...
1572 (A65054)
1572 (A65054)
FARMTRAC 555 TRACTOR (A65057)
FARMTRAC 555...
