EZR1648 not cutting very well. Oil leak bottom seal of motor
   / EZR1648 not cutting very well. Oil leak bottom seal of motor #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
Hey all,
I am the original owner of a EZR1648. I think it is the 1st or 2nd year model that came out. Anyways, Here lately it ain't been mowing very well. Don't cut the grass, just knocks it down. or leaves strips on the outside edges of the blades, like they ain't turning fast enough.
I have good sharp blades on. New belts on deck and drive belt from clutch to deck. Belt tensioner good and tight. The only thing I can see is the bottom seal on the engine is leaking oil. If this makes it to the belts would it cause enough slippage to cause mower to not mow right?
Second question. Would I be able to change out the seal without pulling the motor off? I haven't looked to see how much room is under there to get to it.
Thanks
Bill
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
Sterling AT (A53473)
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
