Ballast EZ Weights and Class II Boomers
   / EZ Weights and Class II Boomers #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
I think I know the answer I'll receive, but I will ask anyway... /forums/images/graemlins/frown.gif
Have any Class II Boomer owners installed the EZ Weights on the rear wheels?
The rear wheels have only 3, 11/16" accessory mounting holes, 10.25" apart! /forums/images/graemlins/confused.gif
   / EZ Weights and Class II Boomers #2
Have you considered drilling another accessory hole?
I put the EZ Weights on the front of one of my tractors and I fell in love with the concept because it is pretty much idiot proof. (hey I actually did it, it must be simple) /forums/images/graemlins/grin.gif
But seriously, why not just drill another hole, as long as you put it in the right spot, you should have no trouble installing the EZ Weight system.
   / EZ Weights and Class II Boomers #3
Mike here is the link that shows the EZ Weights on my front wheels on a TC 24D.
If you are a little inventive you can come up with a solution!
EZ Weights on a Boomer
   / EZ Weights and Class II Boomers #5
Jerry that is a nice set up. I considered doing something similar but was wary about the strength of the weld over time given the pounding and torque that is put on the shaft. How is yours holding up? How long have you been using it? How thick is the plate? I like the EZ Weight system a lot, it was simple and fast and fairly inexpensive, but I still wonder if I could have done my own.
   / EZ Weights and Class II Boomers #6
Bob,
I would guess it is about !/4", it has been quite a while since I built it. I have been using it about 4 years. I have had no problems and it is very solid. BTW, I have 200 lbs on each side.
<font color="blue"> The rear wheels have only 3, 11/16" accessory mounting holes, 10.25" apart! </font>
Another TBNer came to my rescue! 5030 created some weight brackets for me. The top picture shows the bracket, while the bottom picture shows the weights installed. On Class II Boomers, perhaps the other class NH Boomer tractors as well, when fitted with R4s, use wheels with only 3 accessory bolt holes. When fitted with R1s, there are 4 accessory holes.
I used 8 washers between the bracket and the wheel (to clear the bolt heads that attach the wheel and the welded on nut that the threaded rod screws into) plus 1 washer under the bolt head. The washer under the bolt head wasn't really needed, but I had the washers and I thought it looked better, even though with the weights on, you'll never see them. The back side is a lock washer and a nut. The 1 inch threaded rod the weights hang on can be left removable or secured with threadlocker.
Each wheel has two 50 pound weights (gray weights in the back) and two 25 pound weights (black weights) for a total of 150 pounds per wheel, the maximum New Holland recommends for R4s on Class II Boomers. These 4 weights, fill up the threaded rod, with just enough space on the end for the washer, lock washer and the nut. About 3 threads are showing. Plus they don't extend past the edge of the tire, great for not inadvertently snaring something if you get too close.
I used the washer/lock washer/nut combination instead of the washer/nylock nut Daryl supplied until I determine how much weight I really need. Once I do, I will use the nylock nut and washer.
I also aired up the rear tires to the maximum recommended pressure of 20 psi.
Dick's Sporting Goods has 50 pound weights, with the small center hole for 49 cents/pound (have to buy 2). I had initially bought 2 weights then stopped in a week later and they were on sale for 39 cents/pound.
I could have bought 2 more fifty pound weights to achieve the total of 150 pounds per wheel, but I already had four 25 pound weights I had purchased at Play It Again Sports for 29 cents/pound. If I'd ever decide to exceed (not likely) the maximum weight recommended by NH for R4s, I could replace the two 25 pound weights with two more 50 pound weights for a total of 200 pounds per wheel.
The concept is pretty simple, but if anyone has any questions, feel free to ask away or contact Daryl.
   / EZ Weights and Class II Boomers #8
Mike, your tires are not loaded I assume?
<font color="blue"> Mike, your tires are not loaded I assume? </font>
Correct.
   / EZ Weights and Class II Boomers #10
Any particular reason to not load them? Use your tractor for mowing your lawn? My R4s are loaded, it makes a HUGE difference. No need for wheel weights. My dealer says that each tire holds between 350 and 400 lbs.
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
John Deere 1790 Planter (A50514)
John Deere 1790...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
Pallet Fees (A50775)
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
