Oil & Fuel EZ Way to Refuel?
   / EZ Way to Refuel? #61
All I can tell you is what the packaging says. It can be used to transfer diesel. It is designed for submersion. Cleanliness will be up the user as with any other system. The input end has a cap which can be removed and modified for a filter if you wish to do so but my tractor has 2 filters before the fuel reaches the engine so why would I do this? I don't use dirty fuel containers and I assume I purchase clean fuel. This is my solution to the refueling problem; it doesn't need to be yours. I just thought I would put it out there for thought since we all have this problem and this method works for me.
   / EZ Way to Refuel? #62
This is what I use. Once the fuel can is above the tank (it does have to be up there with this setup) you stick the long end of the siphon into the can, put the end with the primer bulb into the tank opening, close the valve and squeeze the primer until you get fuel flow, then open the valve.
If you want to stop the flow mid-fill, close the valve.
The 3400 has the filler on top of the hood, awkward to get positioned securely enough to pour a full 5 gallon can of diesel. This empties the same can in about 3 minutes.
Sean
   / EZ Way to Refuel? #63
I wasn't trying to dis your choice but just wanted to address some of the trade offs. It is the only electric system I've seen that works with 5 gallon containers but it does pose a problem keeping the pump from collecting dust or dirt while not in the container. How do you keep it clean? Maybe store the whole thing in a big sealed Rubbermaid container?
   / EZ Way to Refuel? #64
My solution to the glug-glug. Get a grommet with a 1/4 hole in the middle, drill a hole in the can to fit the grommet and stick a 1/4" bolt in the grommet to plug the hole. Pull the bolt when you fill up and diesel gushes out both holes in the spout.. the one designed for the fuel to come out and the one designed to let air in. Empties a 5 gallon can like they used to before the epa got hold of them, maybe even better cause the old cans didn't have an air vent that big. Cell phone pic.. sorry.
Ian
attachment.php
   / EZ Way to Refuel? #65
Sean
Very clever Chilly......and I still like the PSE sticker too..:laughing:
   / EZ Way to Refuel? #66
For something cheap that works , look at magic siphon on the internet . I have sold hundreds of these . They are simple and work . They are a piece of hose with a brass end ,with a marble inside working as a check valve . Shake it in the liquid and it siphons . I set my fuel cans on 4 wheeler seat , lawn tractor the same , my tractor I put a soft towel on hood to prevent scratching and fill from there . I sell them to truckers to fill fuel filters , and their hand sprayers out of their saddle tanks . They use hand sprayers and diesel fuel to coat the beds , keeps their load of asphalt from sticking .
   / EZ Way to Refuel? #67
Siphon-$2.99
Can-$9.99
Fuel - $16.45 (and rising)
Hassle free refueling... priceless...you got the picture...
   / EZ Way to Refuel? #69
dcyrilc said:
WOW. Where did you get a tractor that runs on Kerosene?:D
Kerosene? I thought blue meant smurf juice!
2003 Big Tex 10PI...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
2000 Sterling L9513 Winch Truck (A56435)
2000 Sterling...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
