Oil & Fuel EZ Way to Refuel?
   / EZ Way to Refuel?
When you stick it into the fuel, it fills to the level of the fuel, then when you shake it, the fuel starts to move up, which sucks in new fuel from the bottom of the hose. When that "runs out of steam", the check ball keeps the fuel from flowing back out. The next time the hose goes up, the cycle repeats.
As for speed, I don't know, probably depends on how far below the fuel level the end of the hose is.
Aaron Z
Thanks Aaron - I appriciate your help!!!:)
   / EZ Way to Refuel? #45
I use one of these to fuel my stuff
Mine is called a "Jiggler Siphon" and works great. I bought it from the
HF catalog years ago for $5 or so. It uses a clear marble and plastic fitting
on the end, instead of a steel ball.
With a 3/4" PVC hose, I can drain a 5-gal Jerry can in less than a minute.
I use it to drain tractor fuel tanks and transfer diesel to my fueling system.
I am a big fan of this tool.
   / EZ Way to Refuel? #47
I've been told that gasoline is flammable, diesel/kerosene is combustible.
You have been told correctly. Flammable liquids have a flash point of less than 100 degrees F and combustible liquids have a flash point above 100 degrees F.
   / EZ Way to Refuel?
100 degrees F - So on a hot day expect your gas to ignite?
   / EZ Way to Refuel?
I love that the ad says "Not for use with flammable liquids" when the sentence before says it is designed for a 5 gallon kerosene can:laughing:
oh - better tell people with kerosene heaters their kero isn't flammable!!:laughing:
   / EZ Way to Refuel? #50
From wiki
The flash point of a volatile liquid is the lowest temperature at which it can vaporize to form an ignitable mixture in air. Measuring a liquid's flash point requires an ignition source. At the flash point, the vapor may cease to burn when the source of ignition is removed.
The flash point is not to be confused with the autoignition temperature, which does not require an ignition source.
More info coming soon! (A55851)
More info coming...
Sterling 9500 (A56435)
Hydraulic Breaker (A55973)
Hydraulic Breaker...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
