Oil & Fuel EZ Way to Refuel?
   / EZ Way to Refuel? #1
funwithahoe
I have seen some really slick ways to refuel on this forum but I am looking for the easiest and cheapest to be able to leave the can on the floorboard of the tractor. Somehow I manage to spill more using those stupid EPA "No Spill" spouts and they restrict flow - I can pee faster then the deisel comes out.:laughing:
Any takers?
Thanks!!!:)
   / EZ Way to Refuel? #2
Nothing short of buying the over sized splash stop funnels(the really large plastic ones) and using these cans by pulling on the filler(if it is spring retained) to hold it open, no.
   / EZ Way to Refuel? #3
I had a good smart allic idea right up until I read "cheapest".:laughing:
The best idea I've seen yet consisted of a small fuel tank on a stand and a pump. I'm toying with the idea of building a small portable refueling station (25-50 gallons) which can be put into the back of the pickup to take to the station and refill. The rest of the time it would have a home in the shop where it can refuel the tractor easily. Not sure yet whether to use a 12 volt or 110 volt pump. Both have advantages and disadvantages.
   / EZ Way to Refuel? #4
Not trying to hijack the thread but 12 volt fuel pumps and tanks are available for trucks and the L shaped ones will fit under a truck tool box :thumbsup:
   / EZ Way to Refuel? #5
I use a Jaz 14" triangular funnel designed as a way to fast fuel race cars. I cut the long spout to the correct length for a BX. The largest top portion of the flanged spout sizes perfectly to a Kubota fuel port. I also use the optional filter. You just take that whole spout off the can. The top lip on the funnel prevents fuel from sploshing over the top of the funnel on the opposite side. To prevent contaminants from getting into the fuel, I keep the funnel wrapped inside a 55 gal. plastic bag and on a shelf in the garage when not in use to prevent dust from accumulating on the funnel. With the air vent popped open at the top end opposite the pour hole, I can fuel the BX in about 10 sec. without spillage of fuel. This link will place you right at my funnel, however you can scroll up and down the same page to see their other funnels.
http://www.jazproducts.com/funnels.html#14
Another possibility is this little portable fuel station from Blitz. Other of their caddies have to be pumped. They can also be so big that once you get them to the gas station in a pickup, they are sooo heavy to unload. I like how you just elevate this one and allow it to gravity feed. It also is not as heavy as the wheeled caddies and costs much less.
Blitz 15-Gallon Professional Fuel Station™, Model# 11055 | Fuel Caddies | Northern Tool + Equipment
Most of my neighbors have a fuel storage tank on an elevated stand and have the local supplier deliver more whenever needed. I have seen tanks smaller than this one, down to 100 gal. TSC may also carry similar items.
Fuel Storage Tank and Stand — 285 Gallon, Model# 300G | Skid + Stand Tanks | Northern Tool + Equipment
I have seen others use an auxillary transfer tank from the back of their diesel pickup:
Auxiliary-Transfer Tanks | Fuel Transfer + Storage | Fuel Transfer + Lubrication | Northern Tool + Equipment
I have been toying with the idea of a crane like boom that will quick attach to my ROPS. It would allow me to hang a 5 gal. diesel can from the end of the boom and tilt it over, sans spout, and pour into my Jaz funnel with little effort.
   / EZ Way to Refuel? #7
I use the ones I sell at my store, they work great. They are push button style safty cans that don't spill and drain fast. I keep 3 on my truck for refueling.
   / EZ Way to Refuel? #8
   / EZ Way to Refuel?
Does your store have a web-site?
   / EZ Way to Refuel?
Thanks all for some good ideas.:)
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
Enclosed Trailer (A56857)
Enclosed Trailer...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2020 DRAGON ESP...
202479 (A54757)
202479 (A54757)
