EZ-spade/Tree shovel Info?
/ EZ-spade/Tree shovel Info? #1
GRUMPA
Concho, AZ
KAMA/TS354C 35HP 4 cyl 4 wheel drive
After reading a post on these and seeing first hand what it can do its yet another one of those gotta-haves attachments. Now heres the kicker, The ones I've seen in the posts are designed for skiddsteers and/or FEL's with a quick detach feature of which I dont have. I have a Kyoker 160, so I would have to have it made just for that FEL. I've sent e-mails to all the companies that were listed in that post and so far (3) have said no. A couple of them have an adapter for the 3PH so you can use there product but I'm not all that eager to be looking over my shoulder for hours on end and get home with a stiff neck.
I'm sure someone somewhere could supply me with one but so far I've struck out, with markham they havent replied yet and if its like the others, they too cant provide what I would like. I got 4 miles of dirt road to my house and when it rains it pours, water sure can take a road and do a number on it fast. Something like that sure would be handy to keep the water from puddling up on the road. And something like that sure would help to divert the water. So if any of you know of a source for my particular delima please let me know.
/ EZ-spade/Tree shovel Info? #2
Grumpa I have fixed a few buckets like that they were narrow mulcher buckets bu worked on the same principle. A friend of mine would buy them then I would make the mounts for his mulcher buckets. I made them the same size as his loader bucketsoriginal mounts. Its not that hard to change out and from your description you would probably leave it on for a good bit at a time anyhow. Id look into having a local welding shop fab one up
they can make exactly what you want to fit your tractor without having to retool a production line.
I was thinking of that as well, just having it welded up. I can supply the parts for it from my shop (we dont weld), but here at least trying to find a welder that is mobile is a trick. I have no way to transport it anywhere.
2018 Ford Fusion Passenger Car, VIN # 3FA6P0HD6JR217606 (A61165)
2018 Ford Fusion...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
2019 Seadoo Spark Jet Ski (A61166)
2019 Seadoo Spark...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
