EZ-Hitch vs Pat's Easy Change
   / EZ-Hitch vs Pat's Easy Change #1
Newtogreen
Harpers Ferry,West Virginia
JD 4115
I would like to install one of these products on my 4115 to ease the hook up pain. Any information concerning the pros and cons of each hitch would be helpful also how they would affect the 3pth arms if any at all. I do like the fact that the Carter and Sons EZ-Hitch doesn't extend the arms, I also think by sitting on top of the arms you may get more hight. Thanks Larry
   / EZ-Hitch vs Pat's Easy Change #2
I got the Carter and Sons system. I really like it. For me the tension bar would be helpful to hold the rear arms steady.
   / EZ-Hitch vs Pat's Easy Change #3
I have the Pats EZ change and love it.. It makes changing implements a breeze..
the pros are straight forward - a) no more trying to wrangle the 3 pt arms wide enough to go over the implement pins.. Just spread the arms and hold in place with the available spreader bar (a must in my opinion), back up and raise the 3 pt when in position.. b) very quick implement changes c) no more backing up and then having to man handle the implement to get it connected.
the Cons of Pats is that some implements may have clearance problems (ie the pins are situationed so that it is hard to have clearance)..
good luck
Brian
   / EZ-Hitch vs Pat's Easy Change #4
I have the EZ-Hitch and it works as advertised. I haven't used any Colorful Metaphors while hooking up implements since I got it.
I don't think you can go wrong with either product. I just didn't want to have to possibly mess around with my PTO shaft lengths so I got the EZ-Hitch.
70pc 8ft.x 3ft. Grey Metal Roof Panels (A55758)
70pc 8ft.x 3ft...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
MAHINDRA 6110 TRACTOR (A54756)
MAHINDRA 6110...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
2017 Ford F-650 Stakebody Flatbed Truck (A55788)
2017 Ford F-650...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
