Snow Blade Extreme metal products tractor plow
   / Extreme metal products tractor plow #1
wheil1717
Duluth, MN
JD 3320
Hi- new to this site, lots of good info.
I was looking for opinions on the EMP plow for my tractor. I have a JD 3320 with a 300x loader. Thanks
Neil
   / Extreme metal products tractor plow #2
Hi Neil - welcome to TBN. I assume you are talking about a snow plow. I've never used a front mounted plow. I alway used the rear blade to clear the driveway, etc. Even though I have a larger tractor I don't like the idea of pushing snow with the plow attached to the FEL frame. I some times make contact with immovable objects that the rear blade will just bounce over. I would be concerned that the trip mechanism on the FEL mounted plow may not work and I might end up with a damaged frame. I'm sure many use the FEL plow successfully and can give you good advice in that area.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
2023 JACTO JATAO-1000 LOT NUMBER 66 (A53084)
2023 JACTO...
10 in Small Excavator Bucket (A52377)
10 in Small...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
