Snow Blade Extreme metal products tractor plow
   / Extreme metal products tractor plow #1
wheil1717
Duluth, MN
JD 3320
Hi- new to this site, lots of good info.
I was looking for opinions on the EMP plow for my tractor. I have a JD 3320 with a 300x loader. Thanks
Neil
   / Extreme metal products tractor plow #2
Hi Neil - welcome to TBN. I assume you are talking about a snow plow. I've never used a front mounted plow. I alway used the rear blade to clear the driveway, etc. Even though I have a larger tractor I don't like the idea of pushing snow with the plow attached to the FEL frame. I some times make contact with immovable objects that the rear blade will just bounce over. I would be concerned that the trip mechanism on the FEL mounted plow may not work and I might end up with a damaged frame. I'm sure many use the FEL plow successfully and can give you good advice in that area.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
LMC LOT IDENTIFIER 129 (A53084)
LMC LOT IDENTIFIER...
2005 JLG E300AJP TELESCOPIC MANLIFT (A51246)
2005 JLG E300AJP...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
