Extra 12v plug(s) on rear of 2009 John Deere 4520 ?
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #1
shock
Ford 2910
I've received such great information here, I thought I'd press my luck....
I am trying to find an open/extra 12v plug on the rear of my JD 4520 CUT tractor so that I could power a 40 gallon Fimco sprayer.
Right now I have wires running from the battery that I plug into, and I'm trying to find an existing connection on the back to use.
On the right hand side, under the roll bar, I found a set of different wires. One says 'RF(indecipherable) ' and underneath that 'Forward (indecipherable)' on the tag, and has a loopback plug, plugged into it. I assume I don't want to use this for anything....
Next to that is an open plug. When testing with a multimeter, it gets power when I turn the Hazards/light switch all the way to the right-field position, I get power to the plug. I assume then that this plug is for the optional field lights? Can anyone confirm they had an open plug back there like that?
Any other options folks would recommend? I have open slots on the fender for toggle switches but assume I still need to find a power source.
Thanks in advance !
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #2
If that switch position works the way you want to run the sprayer, then you found what you are looking for.
I'm hoping ! Just don't know what the amps draw is from the sprayer vs optional lights and if I'll blow fuses or something. I'm not that good with electrical knowledge...
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #4
Thanks in advance !
If you're not sure or don't want to use the wires back there, why not just make your battery wires permanent and install a switch and SAE connectors to the back of your tractor wherever you want it. That's how I've got one rigged up. I loop the wire around the ROP bar when not in use and when I need it, I just unloop it and connect to the pump. I mounted a switch on the ROPS too. It's a cheap solution.
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #5
Also, Fimco makes a wireless switch complete with sae connectors.
My wiring was easier, as I spray with a boom off the front end loader, so the battery is close by.
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #6
Previous lawn tractor with 2 gal sprayer I just put a plug to the rear tail light. When turning the lights on, the spray pump ran. Lawn tractor I have now has a cigarette lighter socket that is switched.
Don't think you will blow a fuse.
The Fimco wireless switch looks interesting ( $24 Amazon) but still need to get 12v power that is fused.
My spray boom is also on the front, but the pump is on a nurse tank that trails behind.
I just didn't want the extra wires hanging /running along the frame of the tractor
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #8
Got it. Then I'd just splice into the wires on the back and see what happens. Worst thing is that you blow a fuse. I doubt you'll have a problem, I think the wires on those Fimco wire kits are 18 or 22 gauge so it's not drawing a lot of current.
   / Extra 12v plug(s) on rear of 2009 John Deere 4520 ? #9
I have a 2006 4320 cab tractor. I had the cigarette lighter/ power outlet/ option ordered when I purchased the tractor. I don't smoke but I thought it maybe be a useful item later. It is on the left side of the tractor on the interior panel just beyond the hydrostatic range selector. I daisy chained from there to the outside rear of the tractor for my winch with remote control. The winch needed 12 volt. That's all I know.
2014 FORD F-250 UTILITY TRUCK (A58214)
2014 FORD F-250...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2013 Kubota SVL 95-2s Skid Steer (A59213)
2013 Kubota SVL...
Millcreek 5ft 3 Point Aerator (A59225)
Millcreek 5ft 3...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
