External to internal regulator
   / External to internal regulator #1
caper45ca
Massey Ferguson 135
Hello
I am new to this and to tractors to. I have a 1972 MF 135 3 cyl Perkins Diesel with 1550 hours that I just purchased a month ago. Yesterday while blowing snow I noticed the ammeter becoming errati....needle fluctuating alot....I used a voltmeter across the bat terminals and the voltage was going from 13.5-16.5.....My tractor has an alternator with an external regulator....Can someone please telll me or give me a diagram or simple instructions so I may remove both and install a simple GM delco alternator.
Thank You
   / External to internal regulator #2
You might just have a bad regulator, or a bad ground somewhere in the system, or even a slipping belt. Regulator contacts can be serviced if they aren't solid state. If all else fails, you might try buying a GM style " single wire" alternator, popular with hot rodders . If you look for a lower amperage unit, say about 60 amps, you can keep the price down. A single wire to the battery positive terminal, plus the alternator case well grounded through the mounting, is all that is necessary. You will, however, have to come up with a mounting system , a belt adjustment feature, and the appropriate drive belt.
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2013 GMC Yukon SUV (A51694)
2013 GMC Yukon SUV...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
