I've wired up the inside of my shop building and now looking to add an exterior outlet on the side-shed/porch. The inside isn't finished -- just metal fastened to the girts with thin foil-faced insulation in between.
How do folks normally mount outlets in this situation? Surface-mount outdoor rated box and just drill a small hole to pass the wire through from inside? Or mount a new construction/interior junction box to the posts and do a rectangular cut-out into the siding with a weatherproof cover?
If an outdoor junction box, do you just use sheet metal screws to secure it to the building? In either case, how do you ensure a weatherproof seal with the siding?
I'm sure I can figure something out that will work but would love to hear what others recommend, or recommend against.
