Extension cord repair.
   / Extension cord repair.
Update: I used heat shrink. Filled in the chewed areas with liquid vinyl electric tape (Gardner Bender) then put the heat shrink tubing on over that. I did buy some of the rubber splicing tape but it was too thick and I couldn't get the heat shrink tubing over it so just stuck with a few coatings of the liquid electric tape. It worked out very well. Of course that meant that I had to cut the plug off one end. I ended up replacing it with good one. I've used to many cheap ones that were hard to wire and worse than the molded original. The plug that I go was made by a Legrand, made in U.S.A. and was a quality part. It cost $15 which sounds crazy but it was worth every penny. It had various sized rubber compression grommets to fit different cord gauges. Each part was grooved and slotted so it was not possible to make an assembly mistake. The wiring had color coated screws and you just pushed the stripped wire end into a hole and then screwed it down. So, $15 for the plug, $7 for the heat shrink, $5 for the liquid tape. So, I'm in $27 to fix a $90 cord but it is fixed properly and safely and should last a long time.
   / Extension cord repair. #23
YES! For big wire $15 doesnt sound bad to get a good end. You now have an extension cord more capable than when new. And you can repair it easily if theres any more damage in the future.
   / Extension cord repair. #25
I would add, that I cut my 100' heavy cord in halve and added appropriate ends. 50' cords are more handy IMHO.
   / Extension cord repair. #26
Happen here once and started a fire and electrocuted the rat which was still smoldering...
Lucky I was around and smelled smoke... had the 100' cord to a trickle charger on the Dozer.
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Case Titan 3530 (A56435)
Case Titan 3530...
2017 John Deere HPX Gator Utility Cart (A56857)
2017 John Deere...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2003 Big Tex 10PI...
