Extension cord repair.
   / Extension cord repair.
Thanks guys. I think I'll do the heat shrink. The tape I used was 3m electrical tape and it stayed on for 4-5 years but I'd like something more permanent. I will look into that rubber tape though. Would be a lot less trouble and I wouldn't have to cut one of the plugs off.
   / Extension cord repair. #12
"Clean the dirt off first" is probably the best advice given so far. :thumbsup:
   / Extension cord repair. #13
I find that, often, a replacement plug on the female end is an upgrade to the cord.
,,,larry
   / Extension cord repair. #14
Good thoughts so far. I like the heat shrink idea as well.
At work we are not allowed to repair any cords. Even cord ends. I guess its an osha violation or something. All our cords have to have molded plugs and no repairs. OR we have to throw them out.
So needless to say, I have more "repaired" extension cords than I'll ever use:laughing:
   / Extension cord repair. #16
I guess its because you cant trust people to do it right even tho the good replacement plugs capture the conductors securely and provide excellent strain relief. - - What a shame.
,,,Molded female plugs seldom hold up to continuous drain. They heat and loosen. A chain reaction failure.
larry
   / Extension cord repair. #17
larry
Have no idea. I agree that the hubble repair ends are much better than molded ends IMO.
I dont even know for sure if it is an osha viloation? but thats the answer I always get is "If osha sees that, we'll get a big fine", but no one ever gives an answer as to "why".
Only possible thing I can think of is its possible to clip the ground wire, and have a 2-wire cord that "appears" to have a ground prong. But I dont see any reason to do that.
ANd we use those cord ends on different fans and light fixtures. Just not allowed to have them on power tools, or extension cords???? So if a ground prong on a power tool breaks, guess where it goes. (but most tools now only have 2-prongs anyway)
   / Extension cord repair. #18
Scotch 23 rubber splicing tape followed by 33 or 88 vinyl over top. Clean the dirt off the jacket first.
I've done this type of repair. And with heatshrink too.
I'd add recommendation to 'fill' the chewed areas of the jacket to level it out first. Then wrap it with quality vinyl tape or rubber splicing tape or both. Agree on topping with vinyl tape is good because it slides better than the rubber tapr, which seals 100% but is soft and can tear. But the vinyl only has a life of a few years outside, as you know. Heatshrink is better, durable, low-friction, but you have to remove an end.
For filling my current favorite for electrical is black "shoe goo". I've never tried "Liquid Electrical tape" but I bet its the same stuff only runnier. Be advised that even though Shoe Goo is thicker, it "runs" too before it sets, it will flow into and around the other wires, and you may have to refill it a 2nd time to get it 'level' before wrapping. Of course if you wrap it before it sets it will cave in for sure.
And be glad you don't have to pass OSHA inspection.
You forgot to include a pic of the log cabin.
   / Extension cord repair. #19
Split loom tubing could be used if you want a uniform appearance and protection against rodents. Might fit in 3/8" and if not 1/2". Only costs about $15 for 100 foot roll. Will make the cord bulkier but does a good job protecting the cord.
Personally I would just use either high quality duct tape or the stretchable sailors rigging tape.
   / Extension cord repair. #20
I like your store. Here it is $0.99 ft for 1/2 inch.
Bruce
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
2015 Peterbilt 567 Wet Kit T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
