Extension cord repair.
   / Extension cord repair. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I have a heavy gauge, 100 foot outdoor extension cord that spent a year sitting outside while I built my log cabin 10 years ago. It ran from the temp power pole to the work site. During that time rats chewed holes in it in about 20 places. They only chewed through the exterior covering and not through the insulation of the individual wires. At the time, I just wrapped these areas in electrician's tape, which is now falling off. I'd like to make a better repair as these cords are quite pricey.
Anyone have any ideas? Would PlastiDip work?
   / Extension cord repair. #2
Can you put piece of hose over the bad spots and fill it with silicon.
   / Extension cord repair. #4
Use a better grade of tape.
Exactly what I was going to write...
Another option: Cut one plug off, and slide sections of heat shrink tubing over the bad spots, then replace the plug.
   / Extension cord repair. #5
This. ^^^
   / Extension cord repair. #6
They make waterproof heat shrink tubing with adhesive inside it. It works great!!
You need to buy the correct size to fit over the cord (probably about 3/4") and shrink it with a heat gun. It will shrink down to about 60% of the original size and make a waterproof seal.
   / Extension cord repair. #8
Unless you want to cut it, tape it up well and run some small zip ties over the end of the tape. If you want to cut the bad section out or put a new plug on one end then as mentioned, a couple layers of heatshrink will do. If you cut the cord then it's best to solder it back together with layers of heatshrink on each wire then a couple layers over the whole thing.
   / Extension cord repair. #9
Scotch 23 rubber splicing tape followed by 33 or 88 vinyl over top. Clean the dirt off the jacket first.
   / Extension cord repair. #10
If you are going to use tape.. I vote for this rubber tape .. It's good stuff..Much better than the nylon tape
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
