3-Point Hitch Extending the reach of a bush hog
   / Extending the reach of a bush hog #21
If someone in the neighborhood has a larger tractor, boom flail might work ok.
From the Spokane Wa craigslist.
Berti TA 145 flail mower- for specs go to
http://www.bertima.it/schede/ta-tas.pdf
It is a 2001 model the same as the TA 140, about 4 foot width. Needs 50- 80 HP tractor with Cat 2- 3 point and dual hydrolics
Excellent condition - well maintained - new Shedder hammers smooth- no vibrations.
Retails at over $8000.00
Will deliver to Spokane area for $100
Call Dean 208 305-3312
   / Extending the reach of a bush hog #22
Hi all,
I have a bit of a issue. I have a LP QuickHitch attachment and use it with all of my implements including a 48 inch bush hog. This works well for most of my land, but I have a issue with our dam and pond. Our access road to our neighboorhood goes over the dam, and on the pond side there is a steep 12 to 20 foot slope down to the edge of our pond. I can put the tractor on the dam road, and can shuffle the tractor sidewase on the road to get the bush hog down the dam face and bush hog the upper half of the dam face. The problem is that I can't reach far enough down the dam without putting the tractor on the steep face of the dam. Frankly, I'm afraid of flipping the tractor on such a steep slope.
Has anyone heard of extensions that I could put into the 3 point hitch and PTO so that the bush-hog has a longer reach?
Other then that, my other choice is a weed wacker.
Does the tractor have a HST transmission? If so I think youve got it made, esp if you mount the BH direct so its closer to the tractor. Your dam face is probably about 25 degree. The tractor wont flip, but youll probably have to add some front weight to keep the front down. The hst will give you the fine control you need to be safe. Doing it with a gear tractor is quite challenging/dangerous.
larry
   / Extending the reach of a bush hog #25
I agree with SPYDERLK, I do this all the time with our L5030 and M8540. I really prefer the HST, but can manage it with the Hydraulic Shuttle Shift and good brakes. I use my FEL for counter balance and have done this for over thirty years on different tractors without any problems.
   / Extending the reach of a bush hog #26
To Larry, Curly, Moe, and Shemp, you are all so hilarious. It's easy to see why you all have gone so far in life.
Keep the condescension to a minimum.
The lecture on brand names vs. the vernacular was really unnecessary, as was the comment on how far the members above have 'gone in life'. I don't see any credentials in anyone's profile, so you may well be 'sassing off' an airline captain, a priest, a professor, a doctor, a surgeon, an NFL football player, a chef, or maybe someone who's rich in the 'education of life' - something that university/tech school/flight school/residency can't instill.
Relax. We're all here to help each other. If you reeeeaaaallly need to correct someone, become that patronizing high school chemistry teacher that we all loved so much.
If you were somehow joking with your comments, I apologize for the above. If you weren't, don't bother responding.
-Jer. (MD, FRCSC)
Out of curiosity, how "steep" of a slope are we talking about? 15 degrees, 20 degrees etc.
Hi TrippleR,
It's steep. I'll try to get some pictures for you. I'd estimate the steep end of the dam face at 30 to 40 degrees.
Larry
Hi TrippleR,
Larry
Also wanted to add, I brought this up with my Father in Law, that use to own a contruction business, use to be a tabacco farmer and has farmed for about 50 years. His reply was, "I'm not going to tell you to do it, and I'm not going to tell you not to do it." (on putting the tractor on the dam face to back the rotary cutter down to the lower brush).
Which I take as "don't do it".
Larry
   / Extending the reach of a bush hog #29
Larry
He's a wise man. Respect your elders.:)
Steve
   / Extending the reach of a bush hog #30
Larry
Last time someone told me anything like that I ended up in a tracked skidsteer, buried in mud to the point that the tracks weren't visible anymore. I wish I had listened.....that was a bad day.
-Jer.
NEW Work Saver Skid Steer/Sub Compact Grapple (A52128)
NEW Work Saver...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
1975 Trailmobile Enclosed Van Trailer (A52128)
1975 Trailmobile...
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51242)
2014 TAKEUCHI...
