Extending Gravel Driveway
   / Extending Gravel Driveway #11
Won't be so "perfect" 20 years from now though, when the wood has rotted out.
That is not what I hear,,
They built corduroy roads from northwest USA to Alaska during WW2, and some are still in use,,,
It will not matter to me in 20 years anyway,,, :laughing: :D :eek:
   / Extending Gravel Driveway #12
Rot issues are much accelerated in the temperate climate of Virginia, compared to where there is frost at or near the ground surface for up to 9 months each year.
Also depends on the species of available logs (trees).
   / Extending Gravel Driveway #13
Dad's drive was built in the 50's. It is in a cedar swamp of Northern Michigan. It was built as a corduroy roadbed. Over the years he has added more driveway mix to it. Occasionally he gets part of stick coming up through the dirt. Up until last year hes has been hauling semi loads of firewood logs up the drive. Jon
   / Extending Gravel Driveway #14
I am not at all surprised.
Cedar is one of the most rot resistant woods on our planet.
I'll bet they knew that when they built that road too.
   / Extending Gravel Driveway #15
That is what I did with the seldom used portion of my "U" shaped driveway. Some years I need to barricade it for a week when the frost goes out in the spring because it gets soft. I do that to keep others off of it. Our vehicles are fine but the tandem wheeled garbage truck and some delivery trucks would cause some rutting.
Most of the labor comes later when the weeds start growing. I spot spray round-up every 3 weeks or so to keep the limestone white rather than grassy.
Hey Big Tiller, there is a product I use called pendamethalin, that is a weed barrier film. Spray it once a year on your gravel driveway, any weed seed blowing in on top wont germinate through it, any seed below or tuber, wont come up through it. Its orange color lets you see it go down and how well, and fades ina week or two at the most. Works very well for me in a 12 month growing season in Florida.
   / Extending Gravel Driveway #16
I have an existing gravel driveway that I would like to add a "bump out" to. The "bump out" will be approximately 20' wide x 70' long. The existing driveway is a bunch of #1 and #2 stone topped with 57 limestone. Should I copy the way the existing gravel drive is (use #1 and #2 stone as base then top with 57 limestone) or will I be OK throwing 3" of 57 limestone on the dirt and compacting it with a heavy piece of machinery? The extension will not be heavily used which is why if I can save some money, I would like to take advantage of that.
I can't speak to your climate, or your geotechnical conditions, the existing soil profiles, but I can say the efforts required to install are worth doing the best prep, and using the right rock/gravel. Your local land clearing or Asphalt companies who do the work will be knowledgeable enough, even, the yard you are going to order the rock from, ought to be able to give you the correct advice.
I manage engineering firms who are designing roads and bridges for FDOT, and I don't get to avoid expensive professionals to make sure its correct, even for the smallest jobs. ( I don't really do small local roads anyway, all State and US Highways and Intertates)
My offer of advice to you is simpler, and I have done it myself many times and advised others who appreciated it. I have made many driveways and boat/trailer pads out of Limestone, Coquina, (native to Florida) and RCP. Most all were sandy soils, and didn't require a bedding stone. I certainly don't put down fabric if its not needed. I have built a couple of boat ramps into fresh water using geogrid plastic load support, and that's a little tricky to be in the right conditions, not an over night success, you have to be ready when the conditions are right.
Advice: Use bigger rock if you are using a soft limestone. -If you are driving on it, and not necessarily walking. It will become smaller. ASK the cement plant to haul your rocks, and pay it out of the chute, saves a ton of time. My cement ready mix plants don't mind sending a truck full, the turning drum cleans the inside of the drum and the flights for them of bits of hardened concrete. You wot even notice. For the cost of rocks- buying a good recipe for the long run is no more expensive than the wrong material. You are only doing it once.
   / Extending Gravel Driveway #17
Sounds interesting, I'll give it a looksee the next time I get to the farm store.
   / Extending Gravel Driveway #18
My driveway is now all recycled concrete. It works as well as roadbase. Really cant tell it's not roadbase unless you look close. Use to be cheaper than roadbase, but recently it's the same price & often scarce for some reason.
Definitely get the right material the first time. I put in a load of nearly free river rock in front of the shop. It was muddy & I didnt have the cash at the time for good material. It keeps showing up through to recycled concrete. Not horribly problematic, but it annoys me with round fist sized rocks that dont grade or smooth out well.
2005 Ford F150 Pick Up (A47477)
2005 Ford F150...
20X30 ALL STEEL CARPORT (A55745)
20X30 ALL STEEL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
Giyi Telescopic Boom (A53316)
Giyi Telescopic...
