Extended Fuel Tank
/ Extended Fuel Tank #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
How many hours does the 852 last with the standard fuel tank when mowing? Are there any extended fuel tank options?
/ Extended Fuel Tank #2
Depends on which engine you're using and what kind of mowing you're doing.
I'm guessing you are gonna go Honda 13 hp, based on your Diesel thread. From what I could find on the internet, that engine burns 230 g/hph of .7 lb/hph and the tank is 6.1 liters or 6.4 quarts.
As far as an extended fuel tank, take a gas can with you. By the time you mow for two plus hours, you'll welcome a break for refueling.
Thanks for those fuel burn numbers. Does anyone know of an extended tank that is available?
/ Extended Fuel Tank #4
I can't say exactly how long a tank lasts on my 852 with 13 hp honda, but I can say that I have bush hogged about 1.5 acres of very dense & high grass on one tank. Unless you are using the sulky then the limiting factor will by your legs and lungs, not the fuel tank. Even when bush hogging briars and trees ( I use the bush hog to clear out any trees less than 2" ) one tank will last me all evening. The honda really sips the gas.
2006 Acura RL Sedan (A59231)
2006 Acura RL...
Zero Turn Mower (A59231)
Zero Turn Mower...
1996 Geo Tracker (A60352)
1996 Geo Tracker...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
