EXTENDAHOE BUSHING
/ EXTENDAHOE BUSHING #1
graemeian
i HAVE A 1992 CASE BACKHOE WITH EXTENDAHOE. The was a leak inside the extendahoe housing and I now have the bucket and housing removed and will remove the cylinder later today. I plan to replace the seals and both hoses. The extendahoe has four flat bushings on the end of the boom. The material looks like nylon. The bottom bushing is broken. Does anyone know what the composition of the bushing is?
Thank you.
Doug
/ EXTENDAHOE BUSHING #2
Almost certainly UHMW (ultra high molecular weight) polyethylene. McMaster Carr has lots of varieties. I like the variety with carbon impregnated in it. I have used it for sliding pads (but never on a backhoe) on several heavy projects with success.
You can drill and saw it with wood or metal working tools.
I saw that the bushing had cracked as opposed to a pinch break. This led me to think it is possibly delrin or some other name brand of acetal resin. I have made the part. The middle joint and the end of the hoe is above the reservoir. I will remove the cylinder and have hoses made tomorrow.
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
BUCKET MOUNTED HAY SPEAR (A63290)
BUCKET MOUNTED HAY...
2014 GMC 1500 Sierra Truck (A63116)
2014 GMC 1500...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
