Extend Wifi 300 Feet?
   / Extend Wifi 300 Feet? #31
i don't know why people are suggesting travel routers. they have the smallest antenna's possible and are design for single room installs like a hotel.
you want your wifi antenna outside. period. and omni based.
something like this
if you need to bridge to it,
something like this is needed.
   / Extend Wifi 300 Feet? #32
Networking 101 (going off fuzzy memory)
To preface, WiFi is NOT “the internet”.
Let’s simplify:
One device is a “node”
A node can connect to other nodes (computer to printer, or computer to computer).
When multiple computers connect to each other, that is a “network”.
A network (multiple nodes connected) can be configured to connect to each other in three ways:
Wired
Wireless
Mixed (wired and wireless)
Note: wireless can be radio waves or non visible light waves (infrared).
Dissimilar networks need a router to connect.
A router is a smart traffic cop in a busy city. It gets the visitors to homes and businesses efficiently as well as locals out of town efficiently. Speaks many languages.
An intranet is a stand alone network inside a network. An intranet can have a node that connects to an external network, but often, the intranet is physically cut off from outside connections. (Think alphabet organization computers in a secure building.)
An extranet is a private network inside a public network. Usually sales people and their databases connected via VPN.
The internet is the whole of allcomputers interconnected.
The World Wide Web is the contents of those connected devices.
With this summary, here’s what can happen:
1)The SIL “remote” node is connected via wifi access point.
2)That access point has an external antenna that points to another access point in another location.
ProTip: water in tree leaves, concrete and metal all degrade signal. Distance also degrades signal but you can still send 2.4 gHz signals many MILES in a point to point (line of sight) connection.
3) The home “local” access point is connected to a switch (dumb traffic cop) or a router.
4) The router is connected to the internet modem (provided by your internet service provider).
the “local” AP can be the same device (the router) that goes to the modem. But it’s often better to have the AP a separate device that can be modified for a better point to point antenna.
I pulled all this from old memory from a long time ago. There may be some technical errors but I didn’t set out to write a book, just a hint of a summary.
This tech & equip was popular when DSL was rolling out in the 2000’s and friends were sharing their internet connections with distant neighbors who didn’t have DSL yet. Those “last mile” neighborhoods. Nowadays most people think wifi is the internet.
Antenna:
Omni: sends receives radio signal like a balloon (all directions). Shortest send/receive distances.
directional: sends/receives like a garden hose (works great pointed at something, goes farther in that one direction.
Hit YouTube or a general search for a “pringles cantenna” or its equivalent. I might have even mentioned an unused pair of satellite dishes. DirecTV was most popular back in the day. Not sure what/if any difference between Dish and DirecTV was/is in this application.
   / Extend Wifi 300 Feet? #33
An inexpensive wireless bridge will work as well if the product you ordered won't. I set this up to have internet in my shop along with a wireless router. Easy to set up and works perfect. I think the range on these are around 1.5 miles.
Amazon.com: Wireless Bridge, UeeVii 5.8G Outdoor CPE Point to Point Long Range Access with 14DBi High Gain 22 Mimo Antenna, PoE Adapter, 2 RJ45 LAN Ethernet Port, 2-Pack : Electronics
Be careful, these have 10% negative reviews.
The Ubiquiti products mentioned above are high grade. They also have a U6 LR which claimed a 600' reach and is IP54 rated (fully protected against solid objects and splashing of water from any angle.).
   / Extend Wifi 300 Feet? #34
I suggested the travel router I use because it is cheap and has a 400' range.
   / Extend Wifi 300 Feet? #35
I'd do something like this. For $200 is said to be good for 6 miles. Needs ethernet at each end so if you need WiFi in the 300' shop just add any old WiFi router/access point you want.
   / Extend Wifi 300 Feet? #36
should have looked at the actual link of yours, travel routers generally don't have the ability to add antenna's
   / Extend Wifi 300 Feet? #37
In my original suggestion I DID stress to order the external antenna model.
I'm not sure if the longer antennas gained anything. I used it with the same camera distance for a couple of years using the little 3" antennas that came on it. I added the longer ones to try and get past the occasional lack of signal during certain weather conditions. It didn't change much if anything.
On a clear day I can walk out in front of my camera that is 400' from the router and look at my movements almost in real time. That signal has to go all the way to the house and all the way back beyond the camera to my phone. Sometimes it has a lag but the signal is pretty good. I plan to test it a little closer to the gate soon. Hard to beat for $32!
John Deere 5603 (A53314)
John Deere 5603...
2020 Deere 325G (A50123)
2020 Deere 325G...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 40in...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
