Experience running both mid and rear PTOs
   / Experience running both mid and rear PTOs #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I never had a need to run both mid and rear PTOs. Now I'm considering a rear PTO blower, and could cut the grass and blow leaves at the same time.
Any lessons learned on running them together. The tractor is 25 hp and the rear blower only needs 7 HP.
   / Experience running both mid and rear PTOs #2
Dad and I frequently run the mid mount mower deck with the rear pto powered grass catcher on the back 3pt for picking up leaves. This is on our Kubota BX2230 tractors. Approximately 22hp engine, not sure what mid and rear pto's are receiving. Just as with any pto, engage them at engine idle speed, then raise engine speed to the rpms necessary for running the pto's. Usually it is marked on the tachometer(if equipped). Jon
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2010 Case 580N (A60462)
2010 Case 580N...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
