Experience Changing Front Steering Shaft Seal ?
   / Experience Changing Front Steering Shaft Seal ? #1
exohomestead
Midwest
MH CG2310, White GT205, Cessna 140
I found out the seal (4265156M91) around my right steering pivot shaft is leaking. I put about a cup of hydraulic fluid into the axle and after about 1/2 hour it had all leaked out from the right side.
Does anybody have experience replacing this seal? It appears I need to pull the tire and hub housing to drop the steering shaft. There are two bearings for the shaft and the seal. I'm wondering how difficult it is to get in there, replace the seal, and put it all back together.
From the parts diagram, looks like I need to pull the wheel, axle, and metal wheel cover. Once looking at the gears in the hub, pull the big round gear. Then the vertical shaft might drop down and I could slide a new seal over the shaft.
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2013 John Deere 824K (A53472)
2013 John Deere...
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
