Experience Changing Front Steering Shaft Seal ?
   / Experience Changing Front Steering Shaft Seal ? #1
exohomestead
Bronze Member
Midwest
MH CG2310, White GT205, Cessna 140
I found out the seal (4265156M91) around my right steering pivot shaft is leaking. I put about a cup of hydraulic fluid into the axle and after about 1/2 hour it had all leaked out from the right side.
Does anybody have experience replacing this seal? It appears I need to pull the tire and hub housing to drop the steering shaft. There are two bearings for the shaft and the seal. I'm wondering how difficult it is to get in there, replace the seal, and put it all back together.
From the parts diagram, looks like I need to pull the wheel, axle, and metal wheel cover. Once looking at the gears in the hub, pull the big round gear. Then the vertical shaft might drop down and I could slide a new seal over the shaft.
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
BOBCAT T595 LOT NUMBER 153 (A53084)
BOBCAT T595 LOT...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
