Expensive Screw up
/ Expensive Screw up #1
neilkingent
LS 4150
I added some ( thought it was)hydrolic fluid to my 2017 XR4150H. What I didn't realize is that the bucket had leaked rain water into it. The oil on top looked fine but I used a hand pump pushed to the bottom. Probably put about a gallon of water in. Noticed my brakes were groaning . I've changed it 3 times draining the filters but not replacing them. I'm thinking I'll change the oil and filters and call it good.
/ Expensive Screw up #2
If you've got most of the water out you should be okay. The filters should trap water and the hot hydraulic fluid should speed its evaporation. Summer temperatures should assist that.
/ Expensive Screw up #3
Good thing its not super cold….
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
