Expensive Screw up
   / Expensive Screw up #1
neilkingent
Bronze Member
LS 4150
I added some ( thought it was)hydrolic fluid to my 2017 XR4150H. What I didn't realize is that the bucket had leaked rain water into it. The oil on top looked fine but I used a hand pump pushed to the bottom. Probably put about a gallon of water in. Noticed my brakes were groaning . I've changed it 3 times draining the filters but not replacing them. I'm thinking I'll change the oil and filters and call it good.
   / Expensive Screw up #2
If you've got most of the water out you should be okay. The filters should trap water and the hot hydraulic fluid should speed its evaporation. Summer temperatures should assist that.
   / Expensive Screw up #3
Good thing its not super cold….
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 CATERPILLAR 926M WHEEL LOADER (A51242)
2015 CATERPILLAR...
Payment Instructions (A47384)
Payment...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
