Expectations of a Flail Mower
   / Expectations of a Flail Mower #11
My ditch bank flail also has an openable rear cover with three adjustments. The further opened the less recutting and the more material spread out behind the mower. Also the less hp required in heavy material.
   / Expectations of a Flail Mower #12
I don't want to side-track this thread, however I'm on the fence about buying a flail mower. How high can they cut? I normally mow grass at 8" high.
   / Expectations of a Flail Mower #13
My old Seppi has hammers and an adjustable rear hatch. I have the rear hatch wide open. I have the roller on the lowest setting, whereby the rotor is at its highest position. I also have the top link set pretty long, also raising the rotor. It seems to distribute the cuttings pretty evenly set up like that.
This is only the second season I have used it. I will try the hatch closed this fall and see how it works. In this position it mulches more and I assume will add additional load to the tractor, so I may have to go slower. And, it might clump some?
I really like the flail mower compared to my rotary cutter.
The trash door on your Seppi Flail shredder serves 2 purposes; (1) it allows the user to mow/shred tall grasses and crops in one pass.
(2) you can inspect the flail shredder knives without lifting it and crawling under it.
   / Expectations of a Flail Mower #14
I don't want to side-track this thread, however I'm on the fence about buying a flail mower. How high can they cut? I normally mow pasture pasture at 8" high.
If that is your desired height of cut do not invest in one UNLESS YOU BUY A HINICKER 72 inch crop shredder.
   / Expectations of a Flail Mower #15
Thank you! I'll be upgrading my 6' rotary mower. I'll rent a tractor with a mid-mount side mower when I need to mow off creek banks, around the lake, etc., which is normally 1X/yr.
   / Expectations of a Flail Mower #16
I just walked out in the field I cut last week. It was every bit of 8" tall. I have the rear roller set to mow the highest, and I have the top link pretty long, which rolls the mower back onto the roller more, thereby raising it higher. I did not measure the hammer clearance to the concrete slab in the shop, but can do that.
I will get back to you about that dimension.
Doug
   / Expectations of a Flail Mower #18
I am on my second season with A Del Marino 6 foot flail with hammer blades. My experience thus far is they are not great at cutting at a high cutting height. I would say 4 to 5 inches tops. I will try the trick of tilting it backwards with the top link to see if I can get a higher cutting height, but one problem I’ve noticed with trying to cut higher stuff will shoot out the front of the mower and coat the back of the tractor with grass. On the other hand, that darn thing will chew through 4 foot high grass like it wasn’t even there. I noticed that the befco article reference said that they can cut 4 inch material. That sounds like a surefire way to tear up your machine anything over an inch and I’m taking out the brush hog.
   / Expectations of a Flail Mower #19
Curious what it looks like after mowing?
How high was it before you cut it?
I don't have a before picture, but the grass was at least chest high. I will get an "after" picture uploaded tomorrow, if not tonight.
I checked the dimension of hammer tip to the shop floor, and it was lower than I thought it would be. It is 4" off the slab. The grass does not appear to be 4" tall though.
Doug
   / Expectations of a Flail Mower #20
Well ... In a weeks time, it probably grew ... I find the more often I mow, the quicker grows right after, seems to be some kind of jump start!
2017 Freightliner M2 106 AWD Terex Commander C4047 Insulated Digger Derrick Truck (A55973)
2017 Freightliner...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58214)
SKID STEER...
2015 DODGE DURANGO RT (A58018)
2015 DODGE DURANGO...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A56858)
2013 Ford F-550...
HARD TOP FOR CONVERTABLE CAR (A58374)
HARD TOP FOR...
2024 Ford F-750 Box Truck (A55973)
2024 Ford F-750...
