Expectations of a Flail Mower
   / Expectations of a Flail Mower #1
Creightone
Kitties 65 hp
Purchased my first flail mower this year. Does a great job cutting but it does not do a very good job of dispersing the cuttings, they tend to be in clumps. Have I not set up the mower properly or does one expect clumps with a flail mower?
   / Expectations of a Flail Mower #2
What brand did you buy? They may have a tutorial out, as the one I bought (soon to be delivered) did.
Beco, 78 inch with hammers
   / Expectations of a Flail Mower #4
I have a 78" Bestco HD with 3" hammers. Put the rpms up, tilt the front of the mower up, and slow down. Clumps do happen in very heavy brush that slows the hammers down (belts slipping) but it is not the normal result.
  • Good Post
Reactions: bgr
   / Expectations of a Flail Mower #5
I'm expecting my Betsco 68" with Y blades on Monday. the field I'm cutting is an old hay field, no brush. I do have a brush hog for the very few areas with small saplings. I Expect a cleaner look. They have videos online as tutorials.
   / Expectations of a Flail Mower #6
........ Put the rpms up, tilt the front of the mower up, and slow down. Clumps do happen in very heavy brush that slows the hammers down (belts slipping) but it is not the norm.
This ^^^^^
   / Expectations of a Flail Mower #7
That depends upon the size of the saplings and what the max cutting of the Y blades is, usually a finish mower is not going to cut small trees. But it might strip them of any branches and foliage lrding to their death.
   / Expectations of a Flail Mower #8
The Y blades are good up to 1". I plan on using the brush hog for anything bigger.
   / Expectations of a Flail Mower #9
This is from the Betsco website Q&A
   / Expectations of a Flail Mower #10
My old Seppi has hammers and an adjustable rear hatch. I have the rear hatch wide open. I have the roller on the lowest setting, whereby the rotor is at its highest position. I also have the top link set pretty long, also raising the rotor. It seems to distribute the cuttings pretty evenly set up like that.
This is only the second season I have used it. I will try the hatch closed this fall and see how it works. In this position it mulches more and I assume will add additional load to the tractor, so I may have to go slower. And, it might clump some?
I really like the flail mower compared to my rotary cutter.
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
Giyi 72" Mulcher (A57149)
Giyi 72" Mulcher...
2017 Ford E-450 Passenger Bus (A56858)
2017 Ford E-450...
2022 Ram 2500 (A55973)
Volvo EC220DL (A57148)
