Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #1
Jojoredd
Exmark lazer z
Charging problem exmark lazer z
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #2
Do you have 12 volts at the Battery wire on the voltage regulator. Is the voltage regulator properly grounded. May need to make sure the battery wire to the regulator can carry current. I have seen 12 volts at that wire but won't carry a charge current.
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #3
What is the complete model description ?
What engine is in it ?
Richard
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #4
Sounds like it's time to pull the flywheel and have a look at the alternator under it and make sure all the wires are intact. You also need to check the magnets attached to the inside of the flywheel to makes sure none have come loose. Don't really matter what engine brand. they are all basically the same if it's a V twin.
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #5
Still under warranty? Take it back to your dealer
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #6
The 2 white wires on the regulator should have around 30 v A/C at highest RPM. The purple wire at the regulator should have 12 v D/C KOEO .
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #7
Jojoredd
Did you resolve this issue ?
If so, let us know what the problem was.
Richard
   / Exmark lazer z 3 yrs old wont charge ive changed stater battery and voltage regulator can someone please help me out #8
Billy had replaced a battery and two voltage regulators on his '90s 25 hp Kohler. (Country Clipper) It still wouldn't charge. A charge wire from under the fan cover to the battery was pinched under vs fed through a gap as intended. Several years of mowing had allowed the insulation to split and ground out the charge. (>25v AC IIRC) His alt/gen coils weren't harmed at all and he now has $150 worth of spare parts. (2)
When I took auto mechanics in college my best instructors taught that w/o proper diagnosis a guy won't make a living fixing what he doesn't figure out first. I like to think the OP is OK and busy operating vs checking in.
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
