Exhaust stack on B3030 with cab
   / Exhaust stack on B3030 with cab #1
ficord
Bronze Member
USA
Kubota
I'm thinking of making an exhaust stack on my newly purchased used b3030.
Even though I have a cab I still smell diesel exhaust in the cab plus it blows out all over the loader and blackens it.
What is the downfall to having the exhaust going back under the oil filter and up along the cab, as shown in pictures.
The top of the stack can mount to the mirror frame.
My concern is will it get too hot to mount so close to the cab frame one inch clearance.
and that the exhaust might get sucked into the ac filter in the rear of the cab below the roof. Anybody see anything really wrong with this idea that I'm not seeing.
I think i'm going to try and make something up , the worse that can happen is I would have to buy another exhaust pipe from Kubota since I will have to cut this one and have it curve the other way.
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/95635945_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/95635925_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/95635869_o.jpg
   / Exhaust stack on B3030 with cab #2
I think you will have to put a flip cap on the top side or rain will run down into the engine?
Depending on clearance you might even reverse the direction and run it under the tractor to the rear of the cab?
If you go for a pipe up the side then I would try to go with stainless steel, won't rust.
I have a backhoe can't run it to the back, has to go up.
   / Exhaust stack on B3030 with cab #4
Other than rust, which is only a cosmetic issue, you want to make sure that clearance allows for heat buildup with prolonged use. Also you want to be far enough above the cab to eliminate any exhaust fumes. And you'll need a rain cap. Post pics of the finished exhaust.
This is what I have done so far I got 10 feet of 1 inch plastic pipe outside dia is almost 1.5 and formed it with my heat gun . Now I will bring the sample to a muffler shop with a pipe bender. The steel pipe size will be 1.5 od Of course it won't be white also I will put a chrome or stainless perforated guard going up along the window paint the pipe high heat black.
One problem is I can't have it go more then one inch past the roof or it won't fit in my garage. Does anyone know of a flexable top that won't burn? I can stick it on when using the tractor and if I forget when I bring it into the garage it won't cause damage.
The pipe will follow the cab windshield the top is off because it is not attached
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96009341_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96009350_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96009380_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96009358_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96009335_o.jpg
   / Exhaust stack on B3030 with cab #6
I don't think heat will be a problem for the cab or paint. There is a lot of cooling along the exhaust before it gets near cab. Paint the exhaust with black header paint and it should help with rusting. You could also wrap exhaust pipe tape near parts next to potential problem areas. Most larger ag tractors have the exhaust pipe near the pillar of the cab. Doesn't block vision in that location.
   / Exhaust stack on B3030 with cab #7
What about the exhaust pipe getting caught on branches or other low hanging objects, is this a concern?
   / Exhaust stack on B3030 with cab #8
Great idea on useing pvc to mock up the exhaust.
You'll need a rain flipper and I would recommend some sort of shielding near where a stray hand might grab or rub up against it.
You'll also probably get soot on the top of the cab, but it shouldn't be as noticable.
Good luck
   / Exhaust stack on B3030 with cab #9
I wouldn't use an exhaust flap/flipper on top. If you have the tip made, just have them bend/angle the top and then cut the end vertical. Take a look at pictures of JD CUTs with vertical exhaust to see what I mean. Even if a little rain gets in the top it won't matter. Most newer tractors, CUT or Ag, no longer use a flapper at the top.
No flipper, would hit the garage door on the way out. I also went with the pipe straight up since i want the exhaust to blow up not back.
Well it took some doing but its on the B3030 works well and sounds really good. And it blows high up into the air, no diesel smells around the tractor.
Bringing the sample pipe to the exhaust shop did not work out quite as I expected I still had to cut weld and bend the pipe even after it was made. You really have to make the pipe as you go, I also installed a short flex pipe since the cab is rubber mounted and moves. I took allot of extra time making sure there was no stress on the pipe when mounting it all lines up very well i used only three mounting brackets and only had to drill one hole at the edge of the cab, I used the top hole in the mirror braket and one of the bolt holes of the FEL
I will wait on a guard and see how it holds up under use, besides I like the way it blends in with the frame of the cab. Here are some more pictures. http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932367_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932359_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932351_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932340_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932321_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/96932306_o.jpg
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
