Exhaust pipe modification L3700
   / Exhaust pipe modification L3700 #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
I would like to change the outlet location for the exhaust pipe away from the front left tire to somewhere where I don't have to breathe the exhaust. I was thinking of running an extension pipe 2 the outlet the back of the roll bar above my head. I don't have a cab. Has anybody done something like this?
   / Exhaust pipe modification L3700 #2
I changed mine for the same reason, though not as big as yours.
   / Exhaust pipe modification L3700 #3
I've thought of doing that, especially when I'm doing something with the PTO and the wind is a certain direction (mine dumps by the right front tire). As long as you use an extension that doesn't restrict flow you should be good.
Did you leave the connection to the existing exhaust as a clamped connection?
What type of pipe is that? Would I need a pipe bender to do this myself?
   / Exhaust pipe modification L3700 #7
Unless you use flex pipe like Billrog did.
   / Exhaust pipe modification L3700 #8
I removed the existing piece of tail pipe that pointed out the front measured the dia. of the existing pipe bought a 14" length of flex because in Canada that's the longest they'll sell or it would have been longer.
Figured out and measured the off set then bought a piece of tail pipe that the flex would slip into and had them bend it for me. I marked the tail pipe with a felt pen where I wanted it bent then eyeballed it while the fella bent it to what I thought was right. A long piece of flex pipe would have been much simpler. And I'd suggest extending it back farther than in my pick the piece of tail pipe I bought was as long a piece they had in the size I needed. I've since extended it a couple ft.from in the pic.
   / Exhaust pipe modification L3700 #9
Thank you Peter! Maybe this thead will finally get me to modify my tractor's exhaust too. It's something I've been considering doing ever since I got this tractor....my first with a horizontal exhaust. I'm not sure why I put up with the low exhaust that can blow back in my face for so long. I guess I thought it was a fad that would soon be replaced with common sense....after all, most tractors historically had vertical exhausts to avoid that "exhaust in the face" issue. Early compacts had a muffler that could be mounted vertically or horizontally - user's choice.
I'm not sure why consumers ever allowed the horizontal-only exhaust system to become the norm. But I did accept mine that way, so I'm part of the problem. I kept thinking that surely someone would sell a kit to convert to vertical exhaust. But nobody has; that's another mystery.
So much for whatevers; it's way past time to change it. Luckily, the Kubota M59 has a full roll cage with a canope top, so there is more choice of where to run a vertical pipe.
Kinda off the subject, but that full roll cage with the canope top is just about the nicest thing I've ever had on a tractor. It's got about half the advantages of a cab without the disadvantages.
   / Exhaust pipe modification L3700 #10
Almost as usual, Paul short has dealt with the exhaust issue on his Kubota 5740. Possibly works best on a cabbed tractor. I did something similar on a Kubota L2900 only not a nice as Paul's.
Look here at about the 4 minute mark. He may have a separate video on the installation, I don't know.
Kubota 574 upgrades - YouTube
Al
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
2006 Dodge Ram 3500 Pickup (RUNS)(TITLE) (A50774)
2006 Dodge Ram...
Grain-O-Vator Auger Wagon (A50515)
Grain-O-Vator...
1981 FMC Link Belt Crane (A50120)
1981 FMC Link Belt...
