exhaust pipe gasket
   / exhaust pipe gasket #1
simonmeridew
Northeastern Vermont
Kubota L4400
Where can I buy one of those ring exhaust gaskets for my 8N? I don't see any listed in my usual sources for 8N parts.
Also I need a set of front wheel bearings with seals, any ideas?
simonmeridew
   / exhaust pipe gasket #2
the reason you don't see a donut exhaust gasket listed ( gasp! ) is beacuse there is not one.
the tail pipe has a metal flange that is soft and molds to the rounded fitting onthe end of the manifold drop pipe.. there is a clamp.. it has a large and small side.. if you mix them up.. it will leak. otherwise.. fit the pipe to the manifold.. hold in place with a floor jack or something.. tap the bell with a hammer head to fit it.. then clamp.. in the rare case it is an eroded fit or a bad casting from a repop.. you can use exhaust putty.. or cut a strip from a sda can and wrap around the joint.. aluminum fiol works too.. and then clamp..e tc.
wheel seals and bearings are common items... check your local dealer.. or if buying online.. a place like
Antique Tractors - Yesterday's Tractors : Antique Tractor Headquarters int he parts sections...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
Hand Truck (A52377)
Hand Truck (A52377)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
