exhaust pipe gasket
   / exhaust pipe gasket #1
simonmeridew
Northeastern Vermont
Kubota L4400
Where can I buy one of those ring exhaust gaskets for my 8N? I don't see any listed in my usual sources for 8N parts.
Also I need a set of front wheel bearings with seals, any ideas?
simonmeridew
   / exhaust pipe gasket #2
the reason you don't see a donut exhaust gasket listed ( gasp! ) is beacuse there is not one.
the tail pipe has a metal flange that is soft and molds to the rounded fitting onthe end of the manifold drop pipe.. there is a clamp.. it has a large and small side.. if you mix them up.. it will leak. otherwise.. fit the pipe to the manifold.. hold in place with a floor jack or something.. tap the bell with a hammer head to fit it.. then clamp.. in the rare case it is an eroded fit or a bad casting from a repop.. you can use exhaust putty.. or cut a strip from a sda can and wrap around the joint.. aluminum fiol works too.. and then clamp..e tc.
wheel seals and bearings are common items... check your local dealer.. or if buying online.. a place like
Antique Tractors - Yesterday's Tractors : Antique Tractor Headquarters int he parts sections...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2024 Rhino 4155 Batwing Mower (A53473)
2024 Rhino 4155...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
Light Tower (A52377)
