Excavator Recovery From Swamp
   / Excavator Recovery From Swamp #1
HHR
Platinum Member
Northern MN
1997 Daewoo Dsl 801
A local excavator went down a snowmobile trail to rescue a sunken trail groomer. The machine sunk in the same swamp. The recovery took 3 days and at least 3 dozers that were attached at a distance by cables. I think that the excavator is a Daewoo or a Doosan.
I would not take anything across a swamp unless it had amphibious tracks.
The last two photos look blurry. I will try to attach them to this post.
   / Excavator Recovery From Swamp #3
I feel your pain, you still got snowLOLOOLOOLOLOLLOLOLOLOLOLOOL:laughing:
   / Excavator Recovery From Swamp #4
That'll ruin your day.
Its a Hitachi by the way.
   / Excavator Recovery From Swamp #7
I bet that operator is glad to have that top door.
   / Excavator Recovery From Swamp #8
As the owner of an 80,000 lb excavator, I can say thats the kind of thing nightmares are made of!
I was recently informed that the excavator weighs 45,000 pounds.
Over one half mile of cable was used in the recovery.
Once it was out of the hole, they were able to fire it up and drive it out to dry land. (I assume that the water was drained from the oil pan and the injectors were pulled prior to starting to avoid a hydrolock situation)
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2019 Infiniti QX60 SUV (A50324)
2019 Infiniti QX60...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
4001 (A51691)
4001 (A51691)
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
