Excavator Blade: Behind or in Front?
   / Excavator Blade: Behind or in Front? #21
Well, both are correct in certain circumstances.
Super-light machines are very different than minis that way tons: you can easily drag a 1-ton-ish excavator around with the dipper, so anchoring with the blade is more important than ever. Sometimes in front is best, which also keeps rocks off your sensitive bits (wheel motors).
Starting a hole is tough when you can push down with much more force than the weight of the machine. Blade-behind maximizes the downward pressure of your teeth on the ground.
But blade-front allows you to lift more without tipping.
Slopey ground (all I have) means blade positioning is everything.
Totally agree, there is no 1 answer fits all situations. Explained very well!
   / Excavator Blade: Behind or in Front? #22
1. Experts on the Internet say to keep a mini-excavator's blade behind you when digging.
2. Experts on the Internet say to keep a mini-excavator's blade in front of you when digging.
Help.
Try both and decide what you like. I've seen both from lots of operators (me included) with experience all over the map, and they all have valid reasons. Also bear in mind that the answer always "depends" on the particular situation you're in. Just keep operating, thinking, and gaining experience
   / Excavator Blade: Behind or in Front? #23
I'm trying to get up to speed with my cheapo Chinese gas job. So much bad information out there.
For example, people complain that the seat gets hot, so some are saying to insulate the underside of the sheet metal under the seat. But that cooks the engine, which people say is already too hot.
My plan is to remove the door, since it seems to serve no purpose anyway.
Mount a 5" 12 v muffin fan on both sides to move air into engine chamber.
   / Excavator Blade: Behind or in Front? #24
OP, can you post a picture of your mini mini mini machine? That may help us give you some answers. I don't think my experience with my Bobcat will transfer over to your machine.
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
2003 Big Tex 10PI...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
LOT OF 7" CHANNEL IRON (A58374)
LOT OF 7" CHANNEL...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
