ex3200tl enough rough cut horse power
   / ex3200tl enough rough cut horse power #1
JWB53
07 toolcat
looking at ex3200tl, 99% of it's work will be mowing, want to use 6 - 8 foot rough cut deck, do ya think it has enough power, mostly flat to little slope property, cutting 1 to 2 foot high grass thanks
   / ex3200tl enough rough cut horse power #2
Guess that would be 32 hp?? If that is what 3200 stands for,than don't think so,6ft might work,but 5ft would be the size most suitable.
yes it's 32 hp, i need hydrostatic drive, and like the 17,800 price, but to increase hp what model do you think i need thanks
   / ex3200tl enough rough cut horse power #4
I don't know about the models of this brand,general rule is 25 hp for 5 ft cutter,30 hp for 6 foot cutter[5hp per foot].
You could use a 6foot on that 32hp probably no problem,but wouldn't think anything bigger.[also depends on pto hp as opposed to engine hp],depends on weight of tractor,etc.
So if above is correct than 40 -45 hp for 8 foot cutter
On the other hand my ck30 kioti's book says it has 23 pto hp,I use a 5 foot cutter and pretty sure I would have no trouble with a 6 foot cutter,even in tall heavy grass.
Another thought would be weight of a big cutter,[not sure how big the three point lift ones go up to],the bigger ones are just a pull type,and how narrow a place you can get a bigger one through.
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
Horizontal Hydraulic Wheel Press (A59213)
Horizontal...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
CARONI 6' FINISH MOWER (A52708)
CARONI 6' FINISH...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
