EX3200 Hydraulic filter cross?
/ EX3200 Hydraulic filter cross? #1
puckgrinder85
Platinum Member
WI
'13 Yanmar Lx4100
Anyone have any luck cross referencing hydraulic filters for this thing? Looks like there is two for the tractor. I cant find part numbers for the ex3200 or a JD790 anywhere to cross. If anyone can lead the blind I'd appreciate it so I could cross it to hopefully a napa brand or something I can get local and much cheaper for the same thing.
/ EX3200 Hydraulic filter cross? #2
I went to the local auto parts store to get a filter cap wrench to fit the fliters on my Cub Cadet/Yanmar Sc2450, I brought the filters with me
so I could get the right ones and when I was checking out the guy said the he would cross refernce the filters so I could save alot of money.
The oil filter was $10 more and the hydo filter was $15 more than I payed for from the tractor dealer.
I get filters a little cheaper than a walk in customer, just looking for the numbers.
/ EX3200 Hydraulic filter cross? #4
Hey Puck, I have contacted wix about cross ref. the hyd filter for me, they said no current replacement for it. Good luck and please post if you find one.
/ EX3200 Hydraulic filter cross? #5
Have you had any luck cross referencing hydraulic filters? The dealer price is $32 for the HST and $22 for the Oil
/ EX3200 Hydraulic filter cross? #6
Kenred121,
Oil filter is Napa # 1334, you should have the same Yanmar as i have 3ntv88. I have yet to have any luck locating a hyd filter.
/ EX3200 Hydraulic filter cross? #7
Thanks for your reply, just thought I would check here before I purchased from dealer!
Kenred121,
/ EX3200 Hydraulic filter cross? #8
puckgrinder,
can't help with ex3200, but Baldwin Filters E-Catalog lists a number of filters for the JD 790. Please note there is an option to select the correct yanmar engine. Follow the link, Enter John Deere for the manufacture, Tractor as the type and scroll way down for 790.
Model790 Utility Tractor w/Yanmar 3TNE84 Eng.
Filter Baldwin Number Qualifiers
Lube B7216 (M806419)
Trans. BT9346-MPG (RE27284)
Fuel Ele. PF981 To S/N 790001;(M801101)
Fuel Spin-on BF7552 S/N 790001-up;(M811031)
Fuel/Water Separator CLN&R* S/N 790001-up;(M811032)
O. Air PA3785-FN (M802606)
I. Air PA2861 (CH12881)
Model790 Utility Tractor w/Yanmar 3TNV82A Eng.--------------------------------------------------------------------------------
Radial Seal O. Air RS3704 (RG60690)
Radial Seal I. Air RS3705 (RG25644)
WIX Filters:
http://wixfilters.com/Lookup/Applications.aspx?Section=4
Part Part No. Filter Loc Engine VIN Code Comments
Air Filter 42985 790 w / Yanmar Engine S/N LV0790G690001-on (Inner)
Air Filter 46438 790 w / Yanmar Engine S/N LV0790G690001-on (Outer)
Air Filter 42456 790 w / Yanmar Engine To S/N LV0790G690000 (Inner)
Air Filter 46368 790 w / Yanmar Engine To S/N LV0790G690000 (Outer)
Fuel Filter 33263 790 w / Yanmar Engine
Hydraulic 51229 790 w / Yanmar Engine
Oil Filter 5106453 790 w / Yanmar Engine
/ EX3200 Hydraulic filter cross? #9
would that oil filter be the same for the ex3200?
The engine oil fitler is a napa 21334 (proselect filter), whatever that crosses to fits the Ex3200 for the engine oil filter, yes. The JD790 was made by yanmar, look at pictures of them, they are pretty identical. I was assuming the filters were likely the same as well. We have since sold the tractor but to a family member so im sure we'll use this thread some day for his service.
/ EX3200 Hydraulic filter cross? #11
I have been looking in to this today, being a new owner of an ex3200. When I cross referenced the oem part number 198119-48310 (if that is indeed the number for the hst filter) in the wix filter finder, it came up with Wix 51205 for the hst filter. I found one on line for about $25 shipped. The Wix engine oil filter cross references to Wix part numbers 51334 and 51334xp. I don't know hat the difference between the two are, I'm guessing the filter material.
I also have a couple of questions.
What has everyone been finding in the transmission hydraulic oil strainer screen?
and, why did Yanmar make it take 5.4 instead of 5.0 gallons for the capacity? Does it really take 5.4?
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
GMC 6500 (A63291)
GMC 6500 (A63291)
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
Timpte Hopper Bottom (A63688)
Timpte Hopper...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
