EX3200 Dual Rear Remotes
   / EX3200 Dual Rear Remotes #1
Sockwell
Coosa County AL
Kubota L5740-HSTC,CC/Y EX3200, 1950 8N
Have any of you guys with the EX3200's mounted dual rear remotes on your tractor? I saw, and downloaded from another thread, the Rear Remote Valve Kit Assembly Instructions. Looking at the instructions, it appears that the kit uses only hoses, no formed steel lines. Could a second valve be added by using the factory kit and splitting the supply and return lines with tees? I'm looking into buying a stump grinder. Two remotes are required. If possible, I had rather have the remotes that disconnect the loader.
   / EX3200 Dual Rear Remotes #2
I thought there was a discussion about this possibly using the power beyond kit and plumbing remotes using the PB. I have the kit and the lines are metal.
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
