EX3200 Dual Rear Remotes
   / EX3200 Dual Rear Remotes #1
Sockwell
Coosa County AL
Kubota L5740-HSTC,CC/Y EX3200, 1950 8N
Have any of you guys with the EX3200's mounted dual rear remotes on your tractor? I saw, and downloaded from another thread, the Rear Remote Valve Kit Assembly Instructions. Looking at the instructions, it appears that the kit uses only hoses, no formed steel lines. Could a second valve be added by using the factory kit and splitting the supply and return lines with tees? I'm looking into buying a stump grinder. Two remotes are required. If possible, I had rather have the remotes that disconnect the loader.
   / EX3200 Dual Rear Remotes #2
I thought there was a discussion about this possibly using the power beyond kit and plumbing remotes using the PB. I have the kit and the lines are metal.
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2015 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51243)
2015 FORD F750 XL...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
