Everything Attachments is great!
   / Everything Attachments is great! #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I ordered an EA rear blade and have been using it. My place is very hilly, so one end of road I'm putting through woods comes out on a hillside. Just wanted to post my experience about the blade: it's very well made. A big plus is everything is adjustable: angle, tilt left-right...everything.
The cutting bar bottom is replaceable. Wow, you'd never know snagging a tree root except tractor tilts .
So now the road I angled level, then level the blade angled but straight so it pushes material off like I wanted.
So if you're ever thinking about a rear blade think EA!!!!! So nice, and made right here in North Carolina USA. Great welds.
I've been having a blast with it. It may cost more than others, but I bent one from Tractor Supply first use.
This one I use with a hydraulic top link I ordered from Surplus Center 11" one with open center spool valve. That really makes it nice, depth angle of "cut".
I clean horse sand lot with blade turned backwards.
You'll thank me if you get one.
   / Everything Attachments is great! #2
I ordered this one in January. It’s been in the tractor more than anything else this year.
   / Everything Attachments is great! #3
I love mine. It needed some tweaking as I got it before they started adding a kickstand and making it quick hitch compatible. It is currently set up for snow removal.
   / Everything Attachments is great! #4
I have one, probably the same model too. My primary use is snow plowing, but I leave it on essentially permanently as a counterweight to the FEL. Did a little dirt work with it during house construction, but that is well in the past now. It is heavy!
   / Everything Attachments is great! #5
I love mine!
377790 (A48837)
377790 (A48837)
(1) HD 24ft Free Standing Corral Panel (A48836)
(1) HD 24ft Free...
2005 CATERPILLAR 420D BACKHOE (A50458)
2005 CATERPILLAR...
(1) HD 24ft Free...
UNUSED Heavy-Duty Ratchet Load Binder/Chain Set (A50860)
UNUSED Heavy-Duty...
2010 Ford Edge Limited AWD SUV (A48082)
2010 Ford Edge...
